Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 12-07-2008, 05:05 AM
perla perla is offline
radiatior & front hub
does anybodyknow how to replace the radiator & front hub in a 2000 pontaic montana
Old 12-07-2008, 10:07 PM
marks1591 marks1591 is offline
Re: radiatior & front hub
for the hub get a 30 mm socket remove large nut on shaft the remove break caliper then rotor should come off then turn streering wheel to the right or left depending on what hub you are doing and remove the 3 bolts behind hub then use hammer comes off easy well mine did
Old 12-08-2008, 01:44 PM
mhall02 mhall02 is offline
Good thread on hub replacement:
http://www.automotiveforums.com/vbul...ht=hub+bearing
Don't know about radiator, may be that same boat soon. Don't know if it is the upper hose, where it hooks into the rad or the acutal rad yet. So far a very very small leak.
Old 02-16-2009, 03:03 AM
Thanks for the thread on the hub replacement. took care of it buy the way I bought my radiator in ebay for $94 plus shiping it was a good deal
