96 grand am coolant change
have a 97 grand am v6. 3.1. I want to flush my coolant but i cant find the drain in order to drain it... is it a screw, bolt, plug? i looked underneath the car by the radiator, but couldnt find anything. the frames in the way.. unless im missing it.
Re: 96 grand am coolant change
You might be able to see it better from the top? I think it looks like a wing nut but it is plastic.
Yep, its on the driver side of the cars radiator on the bottom corner you'll definitly see it better from the top.
I would be carefull with the drain cock on these. If it doesnt want to turn I wouldnt force it or it could break off.
![]() At that point you would have to pull the radiator hoses off and pop out a blcok drain to get the rest out. Thier are two block drains, both are located on the sides/center(front - rear of engine compartment)of the block. They have a square hole in them which a 3/8" ratchet end will fit into to loosen. Hope that helps
1999 Grand Am SS 3.4 OHV
