Old 12-06-2008, 10:43 PM
tempfixit tempfixit is offline
95 voyager code questions
95 Voyager 3.3 engine 4 speed automatic 208,000 miles.
Friends vehicle, the check engine lite has come on intermitently. Checked codes are:
12- (disconnected battery) I know the battery has not been disconnected. I will try cleaning up battery cables and posts, seems like on this vehicle this needs to be done more than usual. Could this be a bad ground someplace??? This code has me stumped.
32- (2 seperate codes) Short or open in the EGR solenoid circuit. I will check the connector for looseness. Engine runs fine no problems, mpg seems to be the same.
Any ideas, thanks
Old 12-07-2008, 12:39 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 95 voyager code questions
Don't knock yourself out on the code 12. It will not make the check engine light come on. It means the PCM had a power interruption in the last 50 key cycles usually caused by disconnecting the battery. Since you haven't and all is running well, I wouldn't sweat it. At most check the battery as you're planning. On the rare occassion I check codes on my van it always has a code 12 and runs just fine.
Code 32 equates to a scanner code P0403. Here's the skinny: http://www.obd-codes.com/p0403
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
