Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 12-06-2008, 02:57 PM
jcmcdaniel jcmcdaniel is offline
2004 exepedtion brakes are applying while driving
Help! I have a 2004 expedtion and while driving down the road the brake are applying. They are not completely locking up just applying to all 4 wheels. This has happened about 3 times and it seemed to fix itself when i stopped and pumped the brakes. However, today while driving they applied and pumping brakes did not help. The brakes pads are new and the rotors are in good shape. What could be the problem? Thanks
Old 12-06-2008, 03:48 PM
rhandwor rhandwor is offline
Re: 2004 exepedtion brakes are applying while driving
If you have abs pull the fuse and check if it stops. If this is the case have a shop pull the codes for you. Then either fix it yourself or take it to a shop.
