Old 12-06-2008, 01:41 PM
heelsrule04 heelsrule04 is offline
Heating
I need help with this car. I have a 00 Sunfire and it blows out cold air when you have the heat on. The thermostat is good, the heater core has been replaced and its still doesnt heat. Only one of the lines gets hot. What could this be?
Old 12-06-2008, 05:28 PM
Jaysicle Jaysicle is offline
Re: Heating
Possible blockage?
Flush system. Entire system not just radiator.
~13 litres total - I believe the rad holds ~4 litres of that.
Old 12-06-2008, 09:33 PM
muff34 muff34 is offline
Re: Heating
what line gets hot,heater line or rad hose?
Life Is A Highway ,Enjoy The Ride
Old 12-09-2008, 05:45 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Heating
Originally Posted by heelsrule04
...Only one of the lines gets hot. What could this be?
A restriction in one of the heater hoses. Remove both heater hoses (at the side not on the heater core), and alternate blowing water and air backwards through them until the water comes out clear, then do it forward until the water comes out clear, and just go back and forth until the water's always clear.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
