Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-06-2008, 11:40 AM
kmanracing24's Avatar
kmanracing24 kmanracing24 is offline
Rear End Clunking
Whenever I hit the gas when the RPMs are under 1000 (while I am moving engine kind of bogs for some reason also) something in the rear end clunks until the RPMs match better with the speed. I have a 1985 Caprice 305. Does anyone know what the problem may be? Thanks.
1985 Chevy Caprice Classic 5.0L
1995 Honda CBR600F3
2000 Chevy Cavalier Z24 5 speed
Old 12-06-2008, 12:17 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Rear End Clunking
What you are describing to me sounds like a worn U-joint or two. It's a rattling clunk sound that changes with acceleration. It also projects rearward so it could sound like it's coming from the rear axle.
With the car stopped and your foot on the brake, shift it into drive, then into reverse, then into drive again and then into park. If you hear a loud clunk each time you shift it, the problem is likely to be the U-joints.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-06-2008, 02:47 PM
j cAT j cAT is offline
the other componets to check would be the motor and transmission mounts as well as the transmission tail shaft bushing..
Old 12-07-2008, 01:00 AM
Yeah I did what silicon said to try and there was no clunking whatsoever. Thanks for the replies
1995 Honda CBR600F3
Old 12-07-2008, 09:58 AM
with the front wheels secured/blocked jack up the rear wheels . place vehicle in neutral and manually rotate the drive shaft and inspect for u joint and bushing wear.....also look for grease /rust being throw by the U joints..
If this is ok check the diff oil for level and color if grayish drop cover and clean replace oil...
