Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-05-2008, 05:30 PM
wigglewerks wigglewerks is offline
Rods
96 Eclipse. Need to remove the pistons and put in some new rob bearings i think, or at least inspect them. Is this something that can be done in a garage. Does anybody have the procedure for doing this, or access to the procedures.
Old 12-05-2008, 05:48 PM
steviek's Avatar
steviek steviek is offline
Re: Rods
it can be done in any garage it just depends on what tools you have in that garage and how much you know about doing this. If you have to ask chances are you probably shouldn't be messing around with your bottom end. But prove me wrong.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 12-05-2008, 06:47 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Rods
If you have to ask, you probably shouldn't be doing it. And how do you know it's your 'rob bearings'?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-07-2008, 04:27 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Rods
You dont need to remove the pistons to get to the rod bearings. You can just pull the oil pan and get to them but I would recommend having the crank polished before you install new bearings to make sure they will last.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-05-2009, 06:30 PM
Re: Rods
I was just wondering if its something that can be done easliy, how bad a job it would be. It's for a friends friend. He seened to thing it needs a rod bearing due to the noise. I was going to remove the pan but wasn't sure if the engine had tobe supported from the top. I didn't do it because he needed it done right away and i was busy reringing a volkswagen. Thanks for the Help?
