hi im new to the forum and need some help with removing my front wheel bearing.i've got everything apart but it seems that the,im not sure what its called,cv joint where the hub nut goes wont pull back or out to let the bearing go.any help or suggestions or ideas please would help.thank you.
oh ya the vehicle is a 2002 chevy venture.
Re: need help with wheel bearing!!
are you sure that that is not a hub and bearing assembly? Which would mean that you need to replace the whole hub and bearing!!!! not just wheel bearing its self
I just had mine done (2000 Silo) to replace a faulty ABS sensor.
The problem with doing nothing is not knowing when you're finished. |
ya it is the hub assembly.i think its just badly rusted ive tried everythig to get it apart but it wont budge i even broke two pulleys tryng to get it out tomorrow im just going to take the axel out with it so i can save the control arm( i likly have to replace the axel now its pretty banged up,) and see if i can get some one to press it out or something how does the axel come out do i just pry it out or does it rotate backwords to onlock and out?thx for the replys
The inner CV joint is just clipped into the tranny (it's an internal clip, not one you have to remove first). All you need is a prybar to gently "pop" the shaft from the tranny. It may take some oomph, or may take getting a slide hammer with the adapter for removing cv shafts, but I haven't had to use mine yet.
thnx dewanyep got it out took it to a mechanic they heated the hub and pounded it off the cv i geuss it was really on there they only charged me 20 bucks and trimed the end of the cv for me.i got a new hub nut for free from the auto zone and im in the process of putting it all back together so far so good only it seems the brake calliper is a little stiff is there any thing i can do or does it need to be replaced.thnx for all the help
Ok, glad to hear you had success getting the shaft out and to a shop. Sounds like it was really seized on there. The brake caliper will not want to retract on older cars when its time to change out the flex line for the brakes. The rubber hose on the brakes wears on the inside and blocks the fluid flow. Its sorta the same as blocked arteries! You won't have any problem using the brake pedal to force the fluid into the caliper and apply the brakes, but it won't want to release so well when that hose is blocked. If that's what you mean by 'stiff' then look over that hose and consider replacing it while you are in there. John |
