Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 12-05-2008, 02:25 AM
Proteusbound Proteusbound is offline
Cable Broken
The cable that attaches to my fuel injector linkage, and goes down to the transmission, is frayed and broken.
Will this cause the variations in shifting I'm having?
Also, will this cause the car to not reshift up into high gear after it "kicksdown" into passing gear?
Old 12-05-2008, 09:45 AM
gorgepr gorgepr is offline
Re: Cable Broken
car?? year ?? engine?? but by your description is should be the overdrive cable and yes that cable messes up the transmision really good change at soon as posible
Old 12-05-2008, 09:54 AM
Morley Morley is offline
Re: Cable Broken
That should be your throttlevalve (TV) cable. Yes, that will cause all kinds of shifting problems.
Old 12-05-2008, 11:50 AM
Re: Cable Broken
Sorry about that.. I picked the Firebird category and thought it would be implied.
1989 Firebird V-6 automatic.
http://i94.photobucket.com/albums/l1...d/000_0312.jpg
http://i94.photobucket.com/albums/l1...d/000_0313.jpg
The car does a bad thing when I'm on the freeway.. if traffic gets slow, or I have to step down on the gas pedal to pass/or on an upgrade, the transmission will kick down into a lower gear, then not go back to drive or Overdrive.
This has been extremely annoying when I'm far away from home, as I have to drive home in second gear..
I try to keep the RPMs below 5000 when this happens.
And when the car cools down after stopping, the transmission is fine again.
Can this cable be the cause?
Old 12-05-2008, 08:52 PM
Re: Cable Broken
yes it should be replace it as soon as posible you dont want to burn the tranny by keeping it on second gear
Old 12-06-2008, 07:35 PM
Re: Cable Broken
Thank you for the replies.. I got a new cable at Pep boys.
Is it relatively easy to replace?
Will I need anything special to remove or install the cable?
Or is it pretty straight forward?
Thanks.
Old 12-07-2008, 09:55 AM
Re: Cable Broken
Thanks.
Pretty easy to do. The only trouble you may have is snaking it down and into place since it is new and will want to go its own way. One thing, make sure to follow the directions for "adjusting" the cable, it is critical.
Old 12-07-2008, 11:25 AM
Re: Cable Broken
Thanks.. I'll give it a shot.
