Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 12-05-2008, 12:22 AM
jknowles87 jknowles87 is offline
Question about gauges
I have a question regarding gauges. I want to put real gauges in my 81 Impala (oil psi, water temp, voltage, tach) instead of the stock idiot lights, and i am wondering, since a camaro gauge cluster has all those gauges in it, will an older 80s camaro cluster fit in my impala? Thanks.
Old 12-07-2008, 02:26 PM
SCU SCU is offline
Re: Question about gauges
I dont think so. Personally, I would look into finding a dakota digital dash or the similar one made by nordskorg.
Old 12-07-2008, 04:16 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The Dakota dash is probably out of price range ... definitely nice but even I wouldn't spring for it under the current conditions.
There is an alternative and that's the U21 gauge cluster that came in the SEO 9C1 spec cars. It was even available in 1981 as a factory component of the 9C1 package. You can see it in the image below (above to the CB mic).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-08-2008, 01:55 PM
U21 gauges? I have never heard of those. I looked it up on ebay and google, and found nothing. The 9C1 120 mph speedo is hard enough to find in early-80s, i can't imagine how hard it would be to locate a set of those...although it does look pretty good in that setup.
If I just knew the dimensions of both the F-body and B-body instrument bezels I would have my answer. I can make them connect right, provided the whole thing would fit in the end.
