Old 12-04-2008, 11:32 PM
rscamaroboy89 rscamaroboy89 is offline
what size downpipe?
i wanna get a downpipe for my gtp.should i go 2.5 or 3"? in the near future ill be dropping to a 3.4 pulley,will the 2.5 be sufficient or should i go 3".within the next year ill be getting a intercooler and dropping even more,so whats gonna help me most now and later to,thanks for any help.
my car 1998 grand prix gtp,borla catback exhaust,fwi,u-bend delete,resonator delete,
180 t-stat,zzp 1.0 pcm,zzp poly motor mounts,zzp shift kit,3 inch high flow cat,3 inch cutout.
not installed:zzp 3.4 mps,autolite 104's
next to order:headers with 3" downpipe
Old 12-04-2008, 11:56 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: what size downpipe?
I'm pretty sure the GP's come with 2.5" exhaust, so unless you plan on replacing the whole exhaust system to 3"...go with the 2.5" it should be sufficient for the 3.4 pulley.
Old 12-05-2008, 09:10 AM
BNaylor's Avatar
BNaylor BNaylor is offline
More like 2 1/4" (2.25"). Also, the stock downpipe is double walled meaning it is two pipes in one. The inner pipe diameter is around 2.0".
Timeslip 08/12/06
AF Community Guidelines
Old 12-05-2008, 09:47 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Interesting thing is, I ordered a 2.5" DP from ZZP, and when it came I measured it and it seemed to be closer to 3" than 2.5"....?????
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-05-2008, 11:35 AM
BNaylor's Avatar
I'm not a fan of aftermarket downpipes. Limited by other exhaust components, flow and backpressure. Exhaust manifolds, CAT converter, resonator, mufflers and the size of the rest of the exhaust plumbing. What good is it with a 2.5" or 3.0" downpipe when the rest of the exhaust is 2.25".
The bottom line is nothing beats headers. Although more expensive the most noticeable bang for the buck.
Timeslip 08/12/06
