Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-04-2008, 06:25 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
shifter linkage
I tried posting this earlier but it refused to work so sorry in advance if a double thread shows up. So anyway whenever i shift into gear it does so with a loud CLUNK. And you have to shift with a firm grip so it doesn't pop into one of the surrounding gears. I looked under the car and i think theres a spring missing from one of teh linkage joints. It seems like its sort of an odd part so i dunno if this is something i could get at autozone or what?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 12-04-2008, 09:12 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: shifter linkage
Are you parked on an incline/decline? If you're parked on level land, then there might be something wrong but if you're parked on a hill or something, then this behavior will happen.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-05-2008, 07:44 AM
bhw33191's Avatar
Re: shifter linkage
No it clunks all the time when i shift no matter what but i'm almost positive its the linkage and not something as serious as you might think it would be. I'm getting my exhaust put on right now so i'll have to get a better look when its done just to make sure.
Old 12-05-2008, 01:43 PM
j cAT j cAT is offline
Re: shifter linkage
if you disconnect the linkage at the tranny and try to move the shifter to see if its internal..
