Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-04-2008, 11:21 AM
jefftig jefftig is offline
slipping in reverse
hi
ive got a dodge ram 2500 with the v-10 2wd slipping in reverse i was going to pull the trans and find a used one just wondering if their might be a fix for this before i do this. any help is appreciated thanks jeff
Old 12-16-2008, 08:43 PM
rockwood84 rockwood84 is offline
Re: slipping in reverse
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one
Old 12-16-2008, 08:44 PM
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your
Old 12-16-2008, 08:45 PM
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your buying. most salvage yards
Old 12-16-2008, 08:46 PM
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your buying. most salvage yards will swap it for
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your buying. most salvage yards will swap it for another one if
Old 12-16-2008, 08:47 PM
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your buying. most salvage yards will swap it for another one if you buy a bad
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your buying. most salvage yards will swap it for another one if you buy a bad one but
Old 12-16-2008, 08:48 PM
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your buying. most salvage yards will swap it for another one if you buy a bad one but your gonna have
every chrysler i had reverse is the first gear to go out ,it will slip at first then one day not back up. you might get a shop to adjust the low /reverse band and buy a little time. but they are most likely to reccommend that you go ahead and rebuild it.if you get a used one you are not gonna know what your buying. most salvage yards will swap it for another one if you buy a bad one but your gonna have to put them
