Old 12-04-2008, 07:53 AM
jbjslambert jbjslambert is offline
Unhappy coolant loss 1997 popular problem i guess
i am loosing coolant like crazy, doesnt show in the oil except maybe a little condensation on back of oil cap, none in the driveway, showing some signs of leaking around rad in the past (green stains on bottom rad hose and such) it leaks down like crazy under a press test, but no leaks found. rad cap didnt hold press so i replaced it. no different or maybe worse now. i have put in 2 gallons in a week of about 150 miles or so. i should see an external leak l ike this with no problem, is what i am thinking, right? other problems are map sensor code and hard to start like flooding. to start it i have to put my foot to the floor to clean out and then release and it will fire up slowly. seems to be excessive steam out the exhaust while warming up, but it doesnt smell sweet like antifreeze.
my thoughts are of course intake plenum problem, but its not showing up inthe oil. maybe lower intake gasket failure? if so how can i tell with out tearing down? ever heard of plenum leaking into throttle body? maybe bad throttle body? -continued-
Old 12-04-2008, 08:01 AM
Re: coolant loss 1997 popular problem i guess
I love a challenge and working on cars, but right now i dont have the money to start trying things like a stab in the dark. this coolant loss is big and has potential to destroy this car so gotta find it. was thinking about tearing down and inspect plenum and replace lower intake gaskets. then if found plenum to be bad then go get the kit. btw i have had a lifter recently start to click or clang mor like it, in the morning. maybe related to coolant loss( washing that lifter out)?? this has got me worried and baffled, car has 130,000 and is in perfect shape other than this, HELP i will check this post regularly and will include any more info you guys or gals might need to help me diagnos this thing. btw love the car, but its soon on my black list,lol. thanks for reading or helping Joe
Old 12-04-2008, 08:02 AM
Talking Re: coolant loss 1997 popular problem i guess
oops i kinda messed up that second post, what can i say i am a newbie,lol
Old 12-04-2008, 08:19 AM
Hapynzap Hapynzap is offline
You need to pull the upper intake off and inspect it around the egr stove pipe. My 1999 Lesabre went out at about 135k. here is no sealer that will fix this. If you let it go you can destroy the engine. I didn't touch the lower intake gaskets. My car runs fine now.
Ive seen plenums on ebay for cheap. I bought this one off the internet myself.
http://www.ineedparts.com/auto-parts...kit-17806.html
1999 LeSabre Limited - 154k
2002 LeSabre Custom - 145k
1985 Century Limited - 252k
Old 12-04-2008, 08:46 AM
thanks for posting, did yours resemble same problem, coolant loss and none found externally? wonder why i am not showing ant in the oil, did yours show it inthe oil? thanks, joe
will be going out for a while, have to drive my gas guzzler quad cab, will check post when i come back
Old 12-04-2008, 09:16 AM
imidazol97 imidazol97 is offline
AF -Advisor
I assume you're filling the radiator to make sure it was full? If your pressure cap wasn't holding, you may have been boiling coolant out.
The description of a shakey start COULD be coolant on the plugs in some cylinders causing misfire at first. You should be getting coolant smell out of the exhaust pipe though.
You might pull the plugs to see what they look like. I believe coolant leaking in will cause a white deposit on the plugs.
Now that the pressure cap is working when parked hot check the elbows on the idler and other heater hose. Check the water pump weep hole with a light and mirror.
Old 12-04-2008, 10:46 AM
nickrhoden nickrhoden is offline
Check your water pump, I had the same problem.
Old 12-04-2008, 01:45 PM
what do you mean by checking elbows on the idler? that the little elbow on the water pump? where is the weep hole, i assume on the bottom of water pump?
Car does alot steaming out the exhaust when first started up, not matter what time of day it is, but it doesnt really smell like anitfreeze or wierd smelling like when you have head gasket leaking. smells somewhat "toxic" but not the same as i have smelled b4 with head gasket problem.
also, if water pump or hoses or nipple on water pump was the problem, wouldnt it show up with the pressure test?
im not questioning anyones thoughts just need to get to the bottom of this thing. thanks, joe
Old 12-04-2008, 03:00 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
With your symptoms, I would bet you have a bad upper intake manifold (UIM). This is a very common problem on 95-98 VIN-K 3800's. The OEM factory EGR stovepipe is too close to the plastic passage in the UIM, so it eventually warps it due to heat causing an internal coolant leak. If you pull the spark plugs out of cylinders 5 and 6, I'll bet you'll have coolant in those cylinders (due to them being closest to the throttle body). Get this changed ASAP or you risk hydrolocking the engine or blowing a head gasket due to the coolant that's getting into the cylinders not being compressable.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-04-2008, 03:14 PM
ya i think i am going to tear it down and replace, wonder if i sould wrap the egr tube with header wrap to help with the heat or maybe heat shielded tape. will prolly go ahead and replace lim gasket while i am there due to little bit oil leaking from edges but not enough to smell or anything, well it might be the valve cover gaskets, huh? thanks all and will post how it goes,joe
Old 12-04-2008, 04:05 PM
richtazz's Avatar
Dorman makes an improved design aftermarket plenum (Part # 615-180) that comes with a new smaller diameter EGR stovepipe that addresses the issue so that won't be necessary. It also comes with the injector o-rings, gaskets, pcv valve, MAP sensor housing, pretty much everything needed in the box.
Old 12-04-2008, 04:44 PM
great, called advance auto and they have that dorman pn for 134.99
Old 12-04-2008, 06:53 PM
auto trainy auto trainy is offline
As far as your pressure test goes the answer is yes,I know from my 95 olds when we pressure tested it we heard a gurggling sound from the TB and then saw antifreeze coming out from it ,it also ran rough when first started which was the plugs being wet,I was lucky and caught it early.When you do the replacement do change the oil and filter and dont take a chance,Good Luck
Old 12-04-2008, 07:24 PM
Yes I was losing coolant with no sign of leakage on the ground
I pulled out my old EGR stove pipe with a hammer slide that you attach a vise grip on it from harbor freight. I used it once and returned it, heh.
Old 12-07-2008, 05:06 PM
doing plenum replacement HELP
whats the best way to reach the bottom nut on the throttle body, its right next to a support bracket and exhaust, thanks,Joe
