Old 12-03-2008, 11:57 PM
z4xx0r z4xx0r is offline
How much does a car's tires turn?
I'm looking for a degree value (maximum left or right from straight) to compare to my design I'm engineering right now. I know it may vary car to car, so a few values or an average would be great!
Thanks, AF!
Old 12-04-2008, 03:19 PM
maxwedge maxwedge is offline
A990 racer
Re: How much does a car's tires turn?
Do you mean from center to lock from straight in degrees, not very clear here. If so it varies car to car.
Old 12-06-2008, 09:22 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
When doing a standard wheel alignment, on the fronts the common practice is to turn the wheel in 20 degrees, zero out the gage, turn it out 20 degrees and you take that as your caster reading.
So I'll say, 20 degrees either way is a ball park figure.
Bob
