Old 12-04-2008, 12:24 AM
d_crosson d_crosson is offline
Is this amp any good?
What are your guys thoughts on Volfenhag amps
I was looking at the eZX7180
Specs:
1600 Watts Max Power @2 Ohms
640 Watts RMS Power @2 Ohms
440 Watts RMS Power @4 Ohms
2ohm stable
Dual Power Meters
Tri-mode capable
Fan cooling system
Soft Delayd Remote Turn On
Variable bass boost:0-18dB
Variable bass frequency:30Hz-100Hz
Channel seperation:>60dB
Signal to noise ratio:97dB
THD 0.03%
Frequency response:20Hz-20KHz
HPF:50Hz-1KHz
LPF:30Hz-250Hz
Adjustable sensitivity range:0.1V-1V
Input impedance:Low level(10K ohms), High level(100 ohms)
Dimension(WxHxL)mm:262x59x429
06 Mustang GT
Performance: lets just say its not stock
Escort Passport X50 radar detector
Blinder X-Treme M27 laser jammer
Laser Veil
Old 12-04-2008, 06:43 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Is this amp any good?
by reputation they are of relatively low quality
