Old 12-03-2008, 01:01 PM
Mark58 Mark58 is offline
S 10 (2003) 4 wd pickup
Newbie here that needs little help,,
My S10 4wd is stuck in 4wd HI,,,pushing buttons and nothing,,,no relay sound like before,,just stuck
Thanks in advance
Old 12-03-2008, 01:05 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: S 10 (2003) 4 wd pickup
Welcome to AF
Is it the auto 4W or regular?
Any shift button lights on or blinking or come on for bulb check.
Any check engine or transfer case lights on?
Have you checked the 4W fuse?
Does backing up or placing transmission in neutral help any?
MT
Old 12-03-2008, 01:13 PM
Originally Posted by MT-2500
Welcome to AF
Sorry,
auto 4 wd
only 4 HI light is on,,pushing 2 Hi and nothing
checked 4 wd fuse,,,OK
Have not tried backing up,,in neutral and park same thing stuck in 4 HI
No additional warning lights on
Thanks
Old 12-03-2008, 01:17 PM
Originally Posted by Mark58
Sorry,
auto 4 wd
Thanks
Just went out and tried in reverse,,,nothing,,put it in neureal and BINGO,,working fine,,,LOL
Thanks
Old 12-03-2008, 05:16 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
Glad you got it to shift.
Could have been in a bind from driving on dry payment in 4W.
Do not use 4W on dry payment.
And use auto mode most of the time for slick higway driving.
Make sure your tires are a matched set.
If it gives any more problems get it on a transfer case scanner and test it out and check for codes.
The Auto 4W needs serviced ever so often with the new blue GM transfer case fluid.
Good luck
MT
Old 12-04-2008, 08:57 PM
You are welcome.
Good luck
Thanks,,
Snowing like crazy tonight,,went to store and it will not shift out of 2 wd,,,
Got to store and tried 4 LO,,works ok ,,,,while moving it will not shift from 2 wd to 4 HI
Thanks again
Old 12-07-2008, 11:42 AM
No luck,,tried shifting into 4WL and both lights 4 WHI and 4WH LO stay on?
Old 12-07-2008, 12:37 PM
MT-2500's Avatar
AF - Advisor
You will need to get it on a transfer case capable scanner and get codes and see what is going on.
Post back any codes.
MT
Old 12-08-2008, 12:30 PM
OK,here is what I have done,,,Read,read and read some more,,Lot's of great info on this site. Now to the issue.
Since I didn't know where to start I took the Battery out,removed the battery base plate,looked at the Vacuum actuator and it was Sucked in with engine off. Is this normal? I disconnected the cable from Vacuum actuator and it stayed sucked in. Used jumper cables started the truck and BINGO ,,,I could switch between 2 HI to 4 HI. of course 4 Lo NO GO. 4 LO is not an issue for me right now as long as I can go from 4 wd to 2 wd.
Do you think Vacuum actuator is my problem?
Thanks
Old 12-08-2008, 02:05 PM
MT-2500's Avatar
AF - Advisor
You need to get it on a transfer case scanner and read codes and do the shift test in the scanner.
MT
