Old 12-03-2008, 08:59 AM
uparms uparms is offline
Wheel and Exhaust Suggestions 1994 C1500
Anyone got any quick numbers on front and rear wheel backspacing, bolt patterns and sizes.
It has the stock 15 inch mags on it. I want to do a Chev. Motor Division rally wheels, 15 inch. stock width (?) front and a slightly larger tire in the back. Can I use the same size wheels ans just add a slightly wider tire in the back??
Any suggestions for an affordable cat back dual exhaust set up?
Any help appreciated.
97K, 1 previous owner, 350, auto, $3700.00. Truck looks and rides like new!
Uparms
1994 Silverado
5.7
Old 12-04-2008, 12:18 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Wheel and Exhaust Suggestions 1994 C1500
You can go slightly wider in the back as long as you also lower your aspect ratio to keep the overall tire circumference the same. This'll keep your speedo/odo calibrated and prevent another thread titled "HELP - MPGs down after tire swap". There are more accurate calculators online, but a rule of thumb I've found is that for every 20mm increase in width, the aspect ratio should be reduced by 5. So in my case for instance, for a stock 245/75-R16, I'd go up to a 265/70-R16.
Also note that by mixing tire sizes, you can't rotate them around to get more even wear. You're stuck with swapping left with right.
Personally, I'd look for bigger diameter rims than 15"...that way the wider tires in the back won't look so balloonish. GM trucks go up to 17" in the same 6-bolt pattern, so you have a nice assortment to choose from.
Don't have anything on dual exhausts...I'm looking around for some myself that dump to the sides so I can haul a horse trailer...may have to go custom. Anybody know better?
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
