Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-02-2008, 06:52 PM
bc6255 bc6255 is offline
04 dakota P0204 error
My son's dakota has a miss. It shows a P0204 error code which is a problem with the #4 fuel injector circuit. I can see no problem. The connector is seated good. I did find some of the relays in the box under the hood were loose. I pushed all of them back down. Engine miss quit. Cleared the error code. Truck ran a few miles, miss started again. Again with the check engine light. Error code P0204 shows again. Don't know where to go next.
Old 12-03-2008, 06:48 AM
2000izusu 2000izusu is offline
Re: 04 dakota P0204 error
try switching the fuel injector with the cylinder next door and see if the code follows the injector! mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 12-03-2008, 04:34 PM
I'll give that a shot as soon as I can.
Old 12-08-2008, 09:02 AM
I found the problem over the weekend. First, before trying the fuel injector swap I did a resistance check between a known good injector and the one that shows a problem. Both show 11.9 ohms each. Not the injector. Traced wires back to computer. Along the way found that the wiring harness had fallen onto the exhaust manifold melting some of the wiring insulation. Made repairs to wiring. Everything is OK now.
