Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 12-02-2008, 10:37 AM
hubbs20qb hubbs20qb is offline
Help Please
Hello
I have a 2006 montana sv6. just wondering how i get the piston back into the caliper on my rear disc brakes.
Old 12-02-2008, 12:34 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Help Please
Will it not go in, or do you just not know how? I usually use a C-clamp. I crank it back in slowly. I never add brake fluid, so I do not remove the cap to the brake fluid resevoir. It just fills back up somewhat when the piston is pushed back in. You have to kind of watch the rubber boot around the piston to make sure it tucks back in nicely. You don't want it to get pinched when the brakes are applied. Hope this helps.
Old 12-02-2008, 11:05 PM
Re: Help Please
Actually i have never seen a caliper like this before. There is a spring that kinda wraps around the caliper and emergency brake cable is there aswell. I used a c clamp like you normally would but this piston is solid, it wont even budge, it kinda looks like it not suposed to move but how can that be.
Old 12-03-2008, 07:29 AM
JabbaTHutt JabbaTHutt is offline
Re: Help Please
are there 2 holes in the end of the piston, the part that would be up against the pad?
2003 Montana EXT
Most options
Niagara Falls
Canada
Old 12-03-2008, 01:03 PM
dewaynep dewaynep is offline
Re: Help Please
I think what JabbaTHutt is getting at is that you have to turn that piston back in, you don't push it back. If you have a local autozone they will loan you the tool to do it or, if you will be doing it often you can just buy the tool.
Old 12-03-2008, 07:47 PM
Re: Help Please
Well the thing is if it has these holes its going to take a special tool or a couple people to do this. The tool is made so that when you turn it it also pushes it back. Was at a buddies shop last week when a mazda was in turns out buddies tool didn't fit it so he borrowed a kit that was supposed to fit it and seems mazda changed the size so we ended up doing a macgiver.
2003 Montana EXT
Most options
Niagara Falls
Canada
