Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 12-01-2008, 10:18 PM
dudewitdamustang dudewitdamustang is offline
front brake rotors
I've taken the brake caliber off. should the rotor come off then...this is on a 2000 mustang
Old 12-20-2008, 03:46 PM
OldSVTGuy OldSVTGuy is offline
Re: front brake rotors
After you remove the wheel and caliper, the rotors should come off. Check to see if there is a little spring nut on one of the lug bolts holding it on. If so, remove it and toss it. It is possible that they are "stuck" on there from corrosion. You can whack it with a small sledge using a piece of wood to prevent damage or you might have to use some heat.
Before I replace my rotors, I always use a small, very small amount of wheel bearing grease to keep them from getting "frozen" on.
Good luck....
