Old 12-01-2008, 08:01 PM
fitenfire4life fitenfire4life is offline
2001 GTP Problem PLEASE HELP!!!!!!!!
I have a 2001 GTP that has just started turning off the trip computer and Daytime running lights when I turn on the A/C and Heater Blower control, it also doesn't work at times. Any insight?
Old 12-01-2008, 08:07 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2001 GTP Problem PLEASE HELP!!!!!!!!
Welcome to AF.
To start make sure your battery and charging system is good. Also, check the battery positive and negative cables and the terminals at the battery.
If that is good then you have an ignition switch acting up.
Timeslip 08/12/06
AF Community Guidelines
Old 12-02-2008, 01:02 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Bob. Start with the simple stuff like loose or corroded battery connections. If that checks out, you're going to need an ignition switch/harness, which is a pretty common issue on these cars.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-07-2008, 11:20 PM
Thank you guys!!!!!! I replaced ignition wiring harness and that cured the problem.
Old 12-07-2008, 11:40 PM
BNaylor's Avatar
Thanks for the feedback and participating on AF.
Timeslip 08/12/06
Old 12-08-2008, 09:20 PM
Another question- My radio display works off and on, so I don't think it is the backlight display? Any insight???
Old 12-08-2008, 10:47 PM
doctorhrdware doctorhrdware is offline
There is a bulb that is behind the display that is going bad. You have to open up the radio in order to replace the bulb.
