Old 12-01-2008, 05:08 PM
p1vanzan p1vanzan is offline
Window Issues
So in the last year three of my windows have broke. I believe its just a piece of plastic holding the wire. Has anyone had these problems and if so do you know where I can get parts to fix them? Thanks
Old 12-01-2008, 08:16 PM
Vanfan Vanfan is offline
Re: Window Issues
Whats the year, make, and model?
Old 12-02-2008, 07:38 AM
Re: Window Issues
1999 Oldsmobile Intrigue GL
Old 12-02-2008, 02:35 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Window Issues
What typically breaks is called the window regulator assembly, and your right its typically some of the cheap plastic stuff that breaks.
What I would do is take off the door panel(s) and do some basic electric troubleshooting to make sure its not a switch or window problem. With the panel off its easy to hear the motor still trying to work. It can be hard to hear with the panel still on.
The regulator assemblies are all over Ebay, most come with a new motor, but there are cheaper ones that use the old motor. The only ones I saw that didnt have motors were for the front windows.
I got the cheapest one I could find, it ended up being a Hollander brand I believe. I was not particularly impressed with i, because although it does work, there was some play in the whole assembly so I can actually move the window back and forth, even with the window rolled up. If my windows werent tinted I wouldve probably never noticed it, but it left like a half-inch strip of untinted window sticking out one day.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 12-02-2008, 11:59 PM
Re: Window Issues
Thanks, Have you done a write up on this?
