Old 12-01-2008, 01:16 PM
Joat_65 Joat_65 is offline
94 V-6 Coolant Leak
Re-ask the question: I have a coolant leak that appears to be coming from under the timing chain cover. Before I tear this apart, is this a possibility? Should I be looking at something else?
Old 12-23-2008, 10:55 PM
zbo2 zbo2 is offline
Send a message via AIM to zbo2
Re: 94 V-6 Coolant Leak
just got done doing my sons 94 w/3.4. yup if it's not the intake gasket , his was not, it's probably the timing cover....took me 4 hours begining to end.
put a new water pump on it while your at it.
Old 06-01-2009, 01:30 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
you might wanna check to belt resistor. when it happened on mt(2000 firebird) I too though it was the intake gasket, so I started pulling $#!t off and saw the the leak was behind the alternator. After closer inspection, I noticed that tensioner had two pvc-like hoses, and one of them was cracked. So that saved me a lot of time and money. Your tensioner might still work but what that is, it has two purposes, the belt tensioner and is a water bypass.
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
