Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-01-2008, 09:27 AM
BWRichards BWRichards is offline
Problems with Starting
I am posting this for my dad. If you can help him, please respond or e-mail me at [email protected]. Thank you.
2001 Dodge ¾ ton diesel
Problems with starting. Will turn over but won’t fire up until you use ether. Once it warms up, it runs good. If you shut it off again it won’t start.
Old 12-02-2008, 02:39 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Problems with Starting
I just went through that.
Do you know the lift pump fuel pressure? The injector pump must have fuel delivered to it, factory spec is at least 10psi idle. How long since a fuel filter change? Does it sit a long time?
Mine was a bad injector pump.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
