keyless entry remote
just got a 1999 grand marquis. I had an extra remote for a 1994 lincoln continental. I'm wondering if I can program it to controll the locks for my grand marquis if soo how. I did it for my lincoln last year and it was no sweat.
"the more they tinker with the plumbing, the easier it is to stop up the pipes" Montgomery Scott |
well i as wondering if somebody could tell me if its like programing the lincoln whee all u gotta do is put the key in the ignition to the acc position and short out a plug in the glove compartment and hit a few buttons if anybody comes accros a "factory manual" on ebay let me know i had one for my lincoln very very handy
My first reply has a link to my mercury .com that has the 99 manual as a pdf file to download FREE.
To program your remote, insert key, turn to position 3 to 4, 4 times within 3 seconds, locks will reset, then press any button on the remote and WALLAH! Doug.
Re: keyless entry remote
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 93 94:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located behind the glove box. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode. These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 95 96 97: Enter 5 digit permanent entry code into the keyless entry keypad. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate successful programming. Press any button on 2nd transmitter (up to 4 transmitters total possible) within 5 seconds of previous transmitter. (if the keypad light goes out before all transmitters are programmed, the entire process must be repeated). Press the 7/8 and 9/0 buttons simultaneously on keypad to exit programming mode. These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 98 +: Diagnostic method of programming transmitters: 1. Choose service bay functions from the service function card. 2. Choose DDM (Driver Door Module) 3. Choose Key Fob Programming 4. Press any button on the remote entry transmitter 5. Choose Fob 1, 2, 3, or 4 and press STORE 6. Repeat steps 4 and 5 for additional transmitters 7. Press Cancel to get out of menu Note: If transmitters do not appear to be working after procedure is complete, disconnect the vehicle battery for 5 minutes, then reconnect and try the transmitter again. |
Re: Re: keyless entry remote
I am a locksmith and one of my clients has purchased a 95 Grand Marquis from an auction .... We have no idea what the 5 digit permanent entry code is. Is there any way to find out?
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 95 96 97: Enter 5 digit permanent entry code into the keyless entry keypad. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate successful programming. Press any button on 2nd transmitter (up to 4 transmitters total possible) within 5 seconds of previous transmitter. (if the keypad light goes out before all transmitters are programmed, the entire process must be repeated). Press the 7/8 and 9/0 buttons simultaneously on keypad to exit programming mode. |
duh! my locksmith husband just informed me about where to look for that code ... sorry ... some locksmith i am :-}
