JMB Performance Fenderwell Intake System
Hey guys, anyone use the JMB Perf FWI system from w-body store?
http://www.wbodystore.com/grandprix/...stem-p-63.html I was thinking about getting one, but read that the "inner fender needs to be cut on w-body cars" and I would really rather not cut anything, especially the body. I read the reviewes and some say "perfect fit, 5 out of 5" and others say things like "needed better instructions". One guy even said that his bumper "sticks out 1/4 of an inch". I would like this FWI becuase if I get black, it will sort of look like its stock and belongs there, and plus since its a FWI, it wont suck in hot air from the engine compartment. But I'm torn on whether or not to take a chance at proper fitment or not. What do you guys think? Anyone have pictures? Thanks!
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: JMB Performance Fenderwell Intake System
Never heard of the brand before. It is true you will have some installation issues with FWI intake systems. Mainly at the cone filter fitting properly like causing a bulge look at the inner fender plastic shield-liner and the big concern which is water intrusion. Unless you install a protective shield it will suck water/moisture big time which could lead to the infamous hydro-lock.
Good Point Bob. I'd rather not hydrolock my motor. Thing is I was looking at the stock airbox intake behind the headlight, and its rather small. Plus being restricted by the headlight and all the wiring.... It seems like it could be restrictive, I dont know.
Here is a better picture....
![]() If only I could find an install tutorial, and someone who has it installed and been using it for quite some time.
The GM intake location is validated thru some furious water intrusion testing.
30mph into a 6" deep trough is like driving into a tidal wave....at least from the driver's seat.
1988 Chevy R-30 1 ton DRW pickup (217k) 1991 Chevy S-10 4WD pickup (192k) 2000 Grand Prix GTP (218k) 2002 GMC Yukon (185k) 2009 G8 - GT (46k) |
Many of us with mods have either a CAI or FWI installed and as long as precautions are taken they work fine and that includes effective protection from water intrusion. I went with the Thrasher CAI which still draws air in from the high pressure area but much better protected from water intrusion.
Where did you get your thrasher Bob?
Click here
I've heard alot of good things about the JMB. everyone that i ever asked said that it works awesome, and the install was much easier than expected.
personally I'm a little weary about cutting the fender also...but again everyone said its easier than expected. i have the same thing as bob in my SE, also got it from 3800 performance...works great.
i amde my fenderwell intake for $20,and it works awesome.that looks alot better than mine but its $200 more than mine.heres some pics.
![]() homemade heatshield that actually works ![]() ![]() after a 20 minute drive home my supercharger is cold to the touch,so it helps alot with cold air.
my car 1998 grand prix gtp,borla catback exhaust,fwi,u-bend delete,resonator delete, 180 t-stat,zzp 1.0 pcm,zzp poly motor mounts,zzp shift kit,3 inch high flow cat,3 inch cutout. not installed:zzp 3.4 mps,autolite 104's next to order:headers with 3" downpipe
