Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-29-2008, 09:38 AM
faze23 faze23 is offline
top speed
what steps are neccesary to allow my eclipse to break the 110 shut off?
other than high performance tires are there any other mods needed to be done, and do i need a new computer or can i have mine reprogrammed?
yea, id say its low
96 eclipse gs, custom ram intake, 4:1 header, no cat, straight through muffler, 2'' lowering springs, rear interior removed and replaced with false bottom, kenwood deck, lightning audio fronts, pioneer rear, rockford fosgate punch series 600w class d mono amp, alpine type r 12'' sub- hit 131.3 at the passenger head rest
Old 11-29-2008, 10:41 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: top speed
The 420a motors do not have a speed limiter. Your car doesn't have enough power to go over that speed.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-30-2008, 01:42 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: top speed
OUCH! I'd sell it and buy a GSX or GSX. They also do not have speed limiters on them; and they can do faster then 110mph.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 11-30-2008, 01:54 PM
Holset powered 420a
Re: top speed
The GSX is limited at 135mph or something like that right?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-30-2008, 01:57 PM
NateS's Avatar
Re: top speed
I have a 95 GSX and I've done just about 160. On a closed course by a professional of course... Haven't hit a limiter yet...
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 11-30-2008, 04:38 PM
Re: top speed
so the reason my car wont build rpms after it hits 105-110 range is? i would except the power explanation if i was redlining but im around 38-4k rpms at this time
yea, id say its low
Old 11-30-2008, 05:51 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Thumbs down Re: top speed
I've hit 120 in mine with bolt-ons. Very stupid to do even though I was riding on Z-rated tires. Why would you want to go that fast? It just takes a long time for the car to get up to that speed, and even then their may be something causing the car not to go faster. Also please tell me that you do that on 93 or higher gas.
And everywhere I've seen the GST/X ECU has the limiter at ~132. I thought DSMLink over rid that or you can take out a capacitor or something.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-30-2008, 09:24 PM
Holset powered 420a
Re: top speed
It takes a good bit of power to push a car that fast. There is a lot of air resistence at that speed and you dont have enough power to push the car any faster. The car being tached out has nothing to do with it. I also hit about 125mph with bolts ons
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-30-2008, 09:48 PM
eagletsi1040 eagletsi1040 is offline
Re: top speed
try biger exhast plus you may not hav enuff fule runing
Old 11-30-2008, 09:55 PM
david-b's Avatar
Dave is THAT guy
Re: top speed
If you're only going to type 11 words, that's more than enough time to spell those words right.
A 2.5" exhaust will help you get there. I don't remember if you've said you have an exhaust on there. Anything bigger will hurt performance. Fuel is fine.
75 Monte Carlo
Old 11-30-2008, 10:40 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: top speed
If you are running traps faster than 110 then you already know how, otherwise you have no business going that fast.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-01-2008, 07:54 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: top speed
I don't see brakes in your mod list, and notice you drive an N/A car...why bother? You can barely get there, then you have no means of reliably stopping. Bad idea.
Kris
2012 Genesis Coupe 2.0t
Old 12-01-2008, 09:03 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: top speed
To the OP, your car must be an automatic???
I had my stock 141 hp spyder rolling 125. But now it will roll 140 quite quickly, then it runs out of gear.
But about the top speed limiter:
GST is I believe 132 or so like previously stated, but GSX doesnt have a limiter, neither does the 2.4L Spyder.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 12-01-2008, 09:52 AM
Re: top speed
ok the exhaust post, airflow is not an option. custom ram air intake with 4:1 aftermarket header, no cat and straight through 2.5 muffler(glass pack) so im sure airflow is not restricting anything.
like i said, i know there are safety measurements that i must update before attempting high speeds. ie braking, wheels.....
im just lost as to why it wont build rpms.... is it computer related or power?
if i need a new chip id rather get that first and then add the bolt ons. i dont want to waste my money on something thats being resticted.
and i cant believe you guys are so critical of me wanting to go faster.... i thought thats what all car/speed enthusiasts wanted.... point taken that most of them dont do so with a gs model but ive got too much time/money into it already to just sell it and buy a gsx, not to mention those are hard to find in the area.
it is n/a for now.... im analyzing my options for a complete rebuild next winter and i cant decide if i want to go with nitrous or turbo, but i do want an idea so i'll know what compression ratio ill need to buy parts for. thats why im posting this, to get an idea of what i can get out of 420a
and your assumption is right, it is an automatic. ive had it since 03 and never intended on it becoming this big of a project or i woulda started with a different model
yea, id say its low
Old 12-01-2008, 09:58 AM
Holset powered 420a
Re: top speed
The auto is your problem. Yes are all like cars but going that fast on the highway is not only dangerous to you but to other as well and thats why we are so critical. To be honest the 420a motor is a POS unless its boosted. Believe me I have been there, the ECU is not the problem. Sure you could pull some more power out of it with more timing and maybe leaner a/f ratio but it wont be significant power.
If you want more power you either need to turbo it or plan on spending a shit ton of money on it and maybe be get to 160-170whp
98 Eclipse GS Turbo
2001 BMW 325i - DD
Closed Thread
