Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-29-2008, 02:49 AM
AppleBag AppleBag is offline
Just had alternator replaced. some symptoms ..
Hi all
I had an alternator replaced 2 years ago. It was still under warranty so I had it replaced again a few days ago. After getting it back, when I drive it at night, the instrument panel (speedometer, etc) lights, as well as my headlights sort of "pulse", brighter and dimmer rather quickly. It's not a hugely noticeable pulse, but noticeable none the less. My car radio also acts strangely now when I press the preset buttons. The light on it goes out for a second and it has trouble pulling in the station, then after a few seconds, pulls it in and the light comes on.
I was wondering what this all could be?
Thanks
Not sure if this is a more generic problem, but just in case it is helpful, this is occuring on a 1999 Mercury Cougar
Old 11-29-2008, 07:18 PM
rhandwor rhandwor is offline
Re: Just had alternator replaced. some symptoms ..
I would make sure your ground wire is clean and tight. Otherwise I would suspect the voltage regulator is pulseing the system.
Old 12-02-2008, 06:59 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
There's a TSB regarding this.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-03-2009, 10:29 PM
sebialx sebialx is offline
i think is the voltage regulator in the altenator
