Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 11-28-2008, 10:23 PM
tombunch tombunch is offline
Exclamation 99 olds silho cranks but no run
i have a 1999 olds my wife drove it to town 30 min later i went to go some were and all it would is crank over i changed the fuel pump and checked all of the fues so can someone please give me some help or some advice
ty
Old 11-30-2008, 11:43 AM
rockwood84 rockwood84 is offline
Re: 99 olds silho cranks but no run
is it firing? stick a phillips screwdriver in one of the plug wires and hold the screwdriver close to some grounded metal and see if it sparks as someone cranks it. if it sparks then you have a fuel problem.
Old 03-13-2009, 07:02 PM
rongbien99 rongbien99 is offline
My 2000 Silo just did this. I went to get gas for the van, my wife car, but die as I was very close to getting there. Ended up filling it up with a container, but now it does not start. It'll crank and appears to run/sputter for very short period of time and die. It just will not turn over. Was wondering what was your fix? Any advice or suggestion would be greatly appreciated.
Old 03-13-2009, 09:44 PM
roadrunner2 roadrunner2 is offline
Did you run it out of fuel or did it die with gas in the tank?
If you ran it out of fuel, you'll have to prime the pump a 1/2 dozen times or so before trying to actually start it.
You can spray a little starting fluid in the throttle body (or the air intake) and if it starts then quits, you'll know it's a fuel supply fault.
Perhaps a faulty fuel pressure regulator.
Tom,
You can try this too.
You said you replaced the fuel pump so that means the fuel filter was too.
Was the tank drained and thoroughly cleaned (and the old gas discarded) before reassembly?
The problem with doing nothing is not knowing when you're finished.
