Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-28-2008, 07:00 PM
SpeedEngineer91 SpeedEngineer91 is offline
420A hesitates under load
Alright guys, I'm stuck. '97 Eclipse RS; drives normal at about 1/2 throttle or less; any more than that and the engine falls on its face. It just sputters and shakes and doesn't rev any higher until you back off the throttle a bit. It's slightly better at higher RPM's, but still extremely present. It seems to run better when the engine is completely cold and it's also cold outside. Idle's basically normal, occasionally you can hear a slight miss. I'm getting 5 different codes:
p0108 - MAP sensor high input
p0113 - Intake air temp. sensor high input
p0123 - TPS high input
p0302 - Cylinder #2 misfire
p0340 - CPS circuit
...it's a mystery. So far I've tried:
New spark plugs
New plug wires
Checked coil resistances
New fuel filter
New air filter
Checked timing
New injectors
Checked compression (~150 across all 4)
EXTENSIVE searching for vac leaks, none found
Visual check of all sensor wiring, no rubs or breaks
I'm stumped; and I'm sick of spending money on guessing. Has anyone had a problem like this before? Any suggestions (fuel press. regulator? EGR? MAP sensor?)? Thanks for the help.
Old 11-30-2008, 12:03 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 420A hesitates under load
Well it says you have a MAP and CPS sensor problem. Any problems with the MAP or CPS will normally cause the car to run like shit. Buy a shop manual at AutoZone and it'll show you how to test all the sensor with a voltmeter to see if they're bad or not. Test the CPS, MAP, and TPS. The CPS will throw the misfire CELs because it doesn't know where the crank is and doesn't know how to fire in correlation to it's position. I'm sure once that is fixed, the others should go away.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-04-2009, 11:53 PM
Adam-C Adam-C is offline
Mine '99 GS has the same issue
If I floor it, no matter what it will hesitate, and the rpm's nearly refuse to raise. and the CEL starts flashing.
unless I back off to around half throttle.
(if i put the car in 3rd, around 20mph or so, and floor it, engine will backfire, sounds like from the intake, could be valve issue?)
I have my own OBD scanner, and it shows a P0302 engine code, nothing else.
I have done compression, fuel pressure, and vacuum tests, all came up clear. Car has had this problem for months, frustrating me to hell!
Old 06-05-2009, 07:16 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Welcome to AF!
Try changing your plugs first. Make sure they are gapped correctly also.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-06-2009, 03:57 AM
New plugs, all gapped correctly, also checked the resistance of the plug wires and coil packs.
Thank you by the way.
I've done many tests in my high-school auto shop and even my autos teacher and a neighboring school's autos teacher were stumped.
Old 06-11-2009, 03:34 AM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Mine runs in reverse. When I gas on it hard it runs great, But at idle it wants to die. I have to gas on it for at least a minute before it idle's good.
Old 06-11-2009, 04:06 AM
within the next couple of days I will be venturing out to the local junkyard in search of a car with an in-shape 420a in it, then i'll probably just take the entire top-end off and see how much it will cost me.
Old 06-11-2009, 07:11 AM
Holset powered 420a
Adam, check your IAC and clean your throttle body.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 06-12-2009, 12:06 AM
Alright, but then why does my ecu record only a cylinder 2 misfire?
Old 06-12-2009, 12:31 AM
david-b's Avatar
Dave is THAT guy
Check for a leak somewhere around the throttle body. I blew my throttle body gasket over the weekend and had the same issue actually. Feel for an vacuum around there or spray some carb cleaner on the TB and see if it gets sucked in anywhere.
75 Monte Carlo
