Old 11-28-2008, 02:30 PM
jrgers jrgers is offline
No spark/no start condition
Howdy all.Great site very helpful.My 96 Windstar 3.0 liter w/150XXX miles will not start.Fuel pressure is OK.Pulled 2 different plugs at different times and locations and no spark.Checked + wire to coil pack has 12+plus volts.Replaced coil pack still no start.Replaced both crank and cam sensors and still no spark.Also replaced ignition control module and still no spark.Checked all fuses,all OK.Checked codes w/Actron reader and said no codes. Visually checked harness did not see anything obvious.A little history.Drove to store,went inside 20 min,came out no start,waited 20 min and tried again,started right up and drove home w/no prob.Waited 30 min and no start/spark condition started.Anyone have an idea.I'm tried of throwing money at it. Thanks for taking time and reading this post.Joe
Old 11-29-2008, 11:05 AM
wiswind wiswind is offline
Re: No spark/no start condition
I will try to help as no one has responded.......I have not been down this path.
You were correct to look at what you have so far.
There is +12V to the coil pack with key in start and run through fuse 20 in the I/P fuse panel (by the driver's left foot).
Spark is provided by the PCM providing a momentary ground to the other end of each coil.
This same fuse provides power to the coil of the PCM power relay (in the engine compartment power distribution box...next to battery).
This relay gets energized by a connection to ground at the other side of the coil....through the CCRM (Constant Control Relay Module).
Black with Ligh Blue stripe wire.
The CCRM is in front of the battery......on the back side of the radiator support.....big electrical connector visible from under the car.
I have pictures of the CCRM in the pictures that the link in my signature takes you to.
There are a couple of different relays inside the CCRM....and 1 can go bad while the others are fine....although I have not seen any posts of the CCRM being the cause of your problem.....it is worth mention as it can.
Power to the PCM through the PCM power relay is through fuse "S" (30amp) in the power distribution box (red wire to the PCM) hot whenever relay is energized.
Yellow wire from fuse "S" to the relay contact is hot all the time.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 02-01-2009, 11:38 PM
searcherrr searcherrr is offline
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Interested to hear what the fix was for this.
I'm very interested in all WEIRD problems that got fixed after someone threw a bunch of money and parts at it.
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
Old 04-07-2009, 02:39 PM
Fulcrum Fulcrum is offline
Sounds like the exact same problem I'm now having, and I don't want to throw a ton of $ at it.
I'm really interested in knowing what the fix was.
Old 10-18-2010, 12:38 PM
dougledbetter dougledbetter is offline
I had the same symptoms (no spark). After troubleshooting several other things, I replaced the crankshaft position sensor and that fixed it.
-dougl
