Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-27-2008, 10:32 AM
ELLES ELLES is offline
Center dash buttons pushed in
I just bought a 00 LS and love it. The problem is that the center dash area has a set of buttons that are pushed into the dash. It is this set:
How do i get in there to get it back?
Old 11-27-2008, 11:48 AM
Re: Center dash buttons pushed in
Disregard i figured it out.
Old 12-17-2008, 05:20 PM
jima4624pY2 jima4624pY2 is offline
Talking Re: Center dash buttons pushed in
mine has the same problem does that panel come off and how did you get it off every time i try to remove it sounds like it's going to brake any advice would be helpfull thanks
Old 12-17-2008, 05:31 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
That upper center dash panel just pulls out. Pull from the sides if at all possible. IIRC, the service manual recommends using hooks to hook the sides and pull evening on both sides.
-Rod
Old 12-17-2008, 05:33 PM
Okay if you just stick a small screwdriver in the sides, lower portion, and push the driver outward on both sides the panel pops out.
Old 12-18-2008, 01:28 PM
i did try pulling it out as even as i could but it sounds like it's going to brake and it looks like the vent's want to come with it i don't know if it's stuck or what the problem is you wouldent happen to have a part number for the panel so when it does brake it have an extra one thanks
Old 12-18-2008, 10:01 PM
shorod's Avatar
SHO No Mo
The vents should come out with it.
-Rod
