Old 11-26-2008, 08:33 PM
deaaa deaaa is offline
Tranny oil spilling out of dipstick tube
Hi, I have a 1998 grand caravan Le with a 3.8. I had transmission oil spill out of the transmission dipstick tube. I refilled the oil to the proper level and made sure the stick was all the way in. About 3 days later I notice tranny oil again spilled out of the tube. I ordered a new dipstick, hoping the new one will sit tighter on the tube. Has anyone had this problem? maybe its something else im missing. Help P.S. this started when it started getting cold out (35 or colder).
Old 11-26-2008, 09:23 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Tranny oil spilling out of dipstick tube
When you check the fluid level are you checking then adding fluid when it is hot as prescribed? Hot meaning after driving 10 miles or so.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-26-2008, 09:48 PM
Yes ,I drove about 4-5 miles and then checked the level with the motor running. I add a little at a time and each time I shift to R,D,2,1,back to R then P before i recheck the level. Could the rubber gaskit go bad on the dipstick? it looks ok, no cracks or missing pieces. There were no transmission services done before this problem happened.
Old 11-26-2008, 10:30 PM
HUNTERPAUL HUNTERPAUL is offline
I have to ask if you checked the transmission oil with the vehicle running in neautral or park. Chrysler transmissions will no pump oil in park and have to be checked while running in neutral. I found this out the hard way.
BR549
Old 11-27-2008, 09:17 AM
No I checked the tranny oil in Park with the motor running. I will check with it in Neautral, I didnt know about that. Thanks and Happy T-Day.
Old 11-27-2008, 09:48 AM
jpb53 jpb53 is offline
Look at your dipstick. It should say check in PARK. Rear whl drive is checked in neutral.
Old 11-27-2008, 06:33 PM
rhandwor rhandwor is offline
Is the fluid leaking where the tube goes into the transmission the problem.
What exactly is the problem?
Old 11-29-2008, 07:23 PM
Tranny oil leaking out of the top of the tube( dipstick) . I just got a new stick from dodge, need to wash area and test drive van to see if it fixed the problem.
Old 12-03-2008, 06:17 PM
Its been about 3 days and no leaks so far. I been checking everyday to see it any area of that part of the engine is wet with oil.
Old 01-14-2009, 05:18 AM
creskick creskick is offline
I have a 96 GM Jimmy and had the same issue only the trans oil was backing up and out of the breather tube. Turned out to be a seal failure between two sections of the trans causing pressure to push the fluid up and out. By the time I found out what it was it had ruined the transmission and had to be rebuilt at the tune of 1600 bucks.
