Old 11-26-2008, 05:37 PM
Big Red 1 Big Red 1 is offline
Question help
On my dash by the stereo is a red light on, it is a anti theft light. It has been staying on. What is it, for the car or the stereo. Don't have a manuel. Thanks
Old 11-26-2008, 06:20 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: help
Welcome to AF !
What year Grand AM ??
It is for the radio, though I think it should be flashing, or off.
If you disconnect the battery or remove the radio with out disabling this security feature, it can make the radio inoperable. This requires a dealership to unlock it, if possible. You need to have the 3-4 digit code the previous owner used if any.
1999 Grand Am SS 3.4 OHV
Old 11-26-2008, 06:23 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: help
Welcome to AF!!
The red light is for the antitheft system. Make sure you are using an original key and not a copy. It is possible that the car may shut off on you at some point. If it does you can reset the system by setting the e brake and then turning the key on for 10 minutes and off for 30 seconds repeat three times and on the third time start the car. You may want to have the car checked by the dealer or a mechanic to see what the actual cause may be if the key is an original.
Old 12-02-2008, 02:35 PM
3100 3100 is offline
Banned
Re: help
remove the plastic around your steering column, below the key cylinder should be a small connector with I think white and yellow or black and yellow wires make sure it is connected.
