Old 03-19-2003, 12:08 PM
lmjacobs lmjacobs is offline
Question Fuses
our '95 burban blows fuses all of the time. however, as of now all fuses are good and the cruise is not working and the AC will not turn on (the AC worked a couple of weeks ago and I switched it off since it was cold and it will not work now). checked the AC fuse. it was good. are there fuses under the hood as well? anyone have similar problems? we just had the AC serviced a couple of months ago and the dealer changed a hose and put in more freon.
thanks for any info you can give!
Old 04-30-2003, 12:59 PM
stu1435 stu1435 is offline
There are also relays that you can replace...
Check under the hood for the "engine" fusebox. Find the 3 or 4 black 1"x1" cubes that are plugged in - these are relays. They usually go out after a few fuses pop.
- Stu
Old 04-30-2003, 01:04 PM
Talking
Check your Chilton's or Other manual to figure out which one is the AC relay...
- Stu
