Old 11-26-2008, 12:30 PM
tpliquid tpliquid is offline
Send a message via AIM to tpliquid
Halp with brake disc color
Im looking to mix the color or carbon discs on the porsche and ferrari cars.
can anyone point in in the right direction as to which colors i need to mix to get the right tone/color?
friends let friends drive benzes
Old 11-26-2008, 01:11 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Halp with brake disc color
The best way to handle this sort of thing (really, the only good way) is to look at some pics of the braking systems you're trying to model. Then simply select the best color (or combination of colors) that match the parts you're trying to represent.
Using a 'recommended' color is arbitrary, inherently subjective, lazy, and usually incorrect.
PHOTOBUCKET SUCKS
Old 11-26-2008, 02:15 PM
klutz_100's Avatar
For example I used a 60% Tamiya Gunmetal / 40% Tamiya flat black mix in the carbon discs HERE
Old 11-26-2008, 03:05 PM
racer93's Avatar
racer93 racer93 is offline
I've found that using a "stipling" technique with Tamiya gunmetal works well. Sorry, no pics of my work, but I've had good reviews of it. Also, I thought just straight gunmetal works pretty well.
Old 11-26-2008, 03:18 PM
thanks for the info guys!!
Old 11-27-2008, 11:04 AM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Not everyone is very good at being able to look at a color and figuring what colors would go together to make that happen. I sure am not. I could try a hundred times to mix some paints and it would look totally wrong, or I could ask what others with a keener eye came up with and get at least a jumping off point.
When modeling, it's good to push your limits, but also good to know them.
Old 11-27-2008, 01:28 PM
675datsun's Avatar
675datsun 675datsun is offline
+1
Well said, Will.
I used the same combo as Klutz, but I also throw in some X-11.
Old 11-30-2008, 01:30 AM
Seamus McRae Seamus McRae is offline
I generally lay down an initial coat of flat black then dry-brush the disk with gunmetal. When all is dry, depending on my mood & chosen subject, I might then do another dry-brush with met grey, in different spots to show some contrast
