Old 03-19-2003, 12:05 PM
cscott784 cscott784 is offline
Send a message via Yahoo to cscott784
Painting Valve Cover
I want to paint my valve cover. Would I need any special paint? and is there a special tool i need for unistallation or would i just bolt it off, paint it, then bolt it back on.
Thanks
Scott
Old 03-19-2003, 12:07 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
get some high heat paint at your local autoparts store ... and yes, basically bolt it off, you may need a new valve cover seal but other than that it will be nice and easy for you.
Edit: Check out my how to on painting the brake calipers, follows the same principle
http://www.automotiveforums.com/vbulletin/t71266.html
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 03-19-2003, 12:08 PM
Great! Thanks Melt. Wow your everywhere. =0)
how much would the gasket cost?
Old 03-19-2003, 12:25 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
DEPENDS...IF U GET JUST THE COVER GASKET OR THE COVER AND SPARKPLUG GASKETS.....RANGE...I THINK $6-$12...DON'T QUOTE ME ON THAT
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-19-2003, 12:33 PM
aces1980 aces1980 is offline
Yeah it's like $13 for the enitire kit. valve cover gasket and sparkplug rings. not bad. i bought mine at autozone
Old 03-19-2003, 01:39 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
like melt said.. get High heat paint! thats a definate MUST!
also. read the labels. try and find a company that makes high heat stuff that protects against oil and grease...
i recommend dupli colour! there great for paint.
heres what i used
Old 03-20-2003, 12:00 PM
Will I need to adjust my spark plugs again? I dont know how to do that, so if it is necessay I dont think I will do it.....
Scott
Old 03-20-2003, 02:52 PM
1PhatCX's Avatar
i have no idea hehe, i just tossed mine back in and didnt think about it... but i think if ur takin the valve cover off cant u just leave the spark plugs in? i'm not too sure about that, maybe someone else can correct me there cuz i dont wanna give u bad info!
Old 03-20-2003, 02:54 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
You don't have to take the spark plugs out, just the wires.
Old 03-20-2003, 10:19 PM
88hondaowner 88hondaowner is offline
Banned
Send a message via MSN to 88hondaowner Send a message via Yahoo to 88hondaowner
use some engine degreaser too. it takes all the grime off then wash it. let it dry and paint away with hi heat paint
Old 03-21-2003, 08:48 AM
Cool! So I dont need to sand it or anything. How many coats and how long should the whole process take. Thanks
Scott
Old 03-21-2003, 05:49 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
i say you have it done right and get it powder coated but if you want to paint it then def. sand it. and put as many coats as needed to cover the valve cover.
