Old 11-26-2008, 08:59 AM
b4j4 b4j4 is offline
99 escort viberate
my 99 escort 2.0 viberates very hard when in gear and at a stop. when i put it in neutral the in cab viberation is less but still bad. any sudjestions..?????
Old 11-26-2008, 11:30 AM
zzyzzx2 zzyzzx2 is offline
Re: 99 escort viberate
Check your motor and transmission mounts.
Check for vacuum leaks (use a MityVac).
Old 11-27-2008, 12:21 AM
Davescort97 Davescort97 is offline
Escort guy
I had the same prob. on mine. I loosened the engine mounts, put a block under the pan with a floor jack, raised the engine about an inch then tightened the mounts back down again. This is called neutralizing engine mounts. Worked for me.
Old 12-05-2008, 01:36 AM
tripletdaddy tripletdaddy is offline
I like everyone else's ideas, but if you are also having performance issues, you may not be firing on all four. Loose plug wire, bad plug, not sure if you have cap and rotor or four lead coil.
Old 02-04-2009, 11:23 AM
Thank you ill give them a try
