Old 11-25-2008, 07:41 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Modding questions....
Hey Guys, Me again, sorry for the stupid questions. Its my friends car. I dont know much about this car. He asked me to do a little research....
1994 Dodge stealth 3.0 V6 DOHC Twin Turbo AWD Manual
Just wondering if anyone knows the stock operating temp of this motor. I'm getting mixed numbers from multiple sources. I'm hearing 195 from some and 180 from others.
Reason I ask is because he wants to start doing some mods. He's got an aftermarket boost guage and says he pushes about 14psi of boost right now.
I dont know much about what all can be done, but I recommended to him to put a little colder stat and some colder plugs in before he starts increasing boost too far to keep knock retard within spec.
Right now he's running one range colder NGK Plat plugs. And would like to swap in a colder stat.
He says he's gonna buy a manual boost controller so he can turn up the boost. What supporting mods would he need to get up to the 20-25psi range? Or is he dreaming?
Thanks, sorry for the stupid questions......
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-25-2008, 08:38 PM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
Re: Modding questions....
Well he is going to need bigger turbos to run that much boost. And a larger fuel pump and larger injectors to keep up with fueling since the stock system is getting close to being maxed out on 14psi. Are you sure he doesnt a boost controller? Because the usually run like ~11psi stock...or maybe his gauge is off
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 11-25-2008, 08:51 PM
AutostradaVR4 AutostradaVR4 is offline
typical warm idle temp is about 180. 195 is about the hottest i've ever seen mine get...that on a really hot day, after a long drive, idling in a parking lot with the AC blasting.
25psi, he may want to look into TD-05 turbos (with supporting mods, as torched said)
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 11-25-2008, 10:18 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Running a colder thermostat has negative effects too. Stock thermostat is good enough.
As for running 14 psi.. I doubt it. Being he doesnt have a MBC he is ost likely running 12 psiish. Stock boost gauge is shit and isnt a real boost gauge.
As for colder plugs, you only want to go colder when you start upping the power a good bit. Running colder plugs now is doing more harm than good.
And for 20-25 psi as was said he needs much bigger turbos. bs are about maxxed at 15 psi.
550 injectors
255 fuel pump
fuel controller
and bigger turbos from 19t, to 15g or something similar will get him around 20-25 psi.
Your friend needs to do his own research and see what hes in for.
Old 11-26-2008, 01:19 AM
tblake's Avatar
In God We Trust
550 injectors
255 fuel pump
fuel controller
Thanks for the great info guys, I really appreciate it. He's thinking about getting some bigger turbo's because right now I think he's having problems with some oil consumption anyways.
BTW, he might have a manual boost controller installed already. He's got something aftermarket on the passenger side near the air intake area.
He also knows the stock boost guage is whack which is why he installed the aftermarket one. I assume he's not exagerating on the amount of boost he's pushing, but never know?....
stealthee, how much $$$$$$ are we looking at here for all these mods you listed above? Do high flow injectors require an modifications to the computer?
BTW, nice car, impressive mods!
Old 11-26-2008, 09:47 AM
can't really modify the ECU in these cars. you'll need an a/f controller
Formerly BlinkRA182
Old 11-26-2008, 11:55 AM
Stealthee's Avatar
As stated you cant flash the ECU like in many other cars. At minimum a SAFC is needed to control larger injectors.
As for cost, off the top of my head
injectors are $300ish
SAFC $200ish
fuel pump $100
and turbos are of course the most expensive ranging anywhere from $700-$2000 (best guess) Just depends on where he looks.
Old 11-27-2008, 01:12 AM
tblake's Avatar
In God We Trust
man you guys are awesome!!!!
One more stupid question if you dont mind....
Whats an SAFC? S A Fuel Controller?
thanks again!
Old 11-27-2008, 10:41 AM
Stealthee's Avatar
Its an Apexi product. Not sure what the S stands for but afc = air fuel controller
Old 11-27-2008, 10:48 AM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
SAFC= Super air fuel controller =)
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 11-27-2008, 02:09 PM
Stealthee's Avatar
DOh, I knew it was something simple. I just couldnt remember.
Old 11-28-2008, 02:38 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
If you need any help with finding parts Shoot me a PM, Also If your friend wants to get larger turbos I can hook you up.
Jason
