Old 11-25-2008, 04:08 PM
chrissbee77 chrissbee77 is offline
Question Scanner for my grand prix
I have a 01 grand prix gt 3.8n.s
I was wondering if ANYBODY knows were i can purchase a transmission capable scanner for less than 300. I dont care what brand i am jsut curious. The shop that did my tranny work told me theres cost about 5300 does that seem right?
Old 11-25-2008, 07:48 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Scanner for my grand prix
yeah, tech 2's or snapon scanners run about that.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-25-2008, 10:00 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
yup, any tech II scanner runs around $5000
you might be able to find a used one for around $3000 but good luck...
Old 11-26-2008, 08:17 AM
BNaylor's Avatar
BNaylor BNaylor is offline
It would help to explain what level of diagnostics you want to perform on the transaxle? To check TCC apply, pressure control and shift timing, etc. you need a GM Tech 2 which means a trip to the GM dealership since obviously the cost of owning one is too expensive unless you are a full time independent auto tech or a shop.
As to just reading out DTCs like a code reader any odb-ii scan tool which has GM manufacturer specific or extended DTC programming can read out the codes which will be both generic in nature (P0XXX) or extended like P1XXX. My Actron scanner will detect and retrieve the extended GM codes like P1810, P1811, P1860, P1887, etc. which are specific to the transaxle.
Timeslip 08/12/06
AF Community Guidelines
Old 11-27-2008, 07:13 PM
troy1 troy1 is offline
AF -Advisor
I use alex peppers scan tool at home. Has little confusing layout but it works great. You need a laptop or desktop for the software.
Old 11-28-2008, 12:51 AM
wlkjr's Avatar
wlkjr wlkjr is offline
That's what I have and I agree about the confusion. Does seem to be a good little scan tool but I wish I knew more of what it will do and how to use it better. Mr. Pepers resume is really impressive.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 11-29-2008, 05:56 PM
Burtnette Burtnette is offline
$5000? Where did you get that price from? My teacher at my automotive school has his own snap on scanner & vantage and he said the vantage was around $2500 and the scanner was $2000. If they really are $5000 he must of got some crazy ass discount then.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
72mm TB w/ TB spacer
WizAired CAI
3" DP w/ Borla Pro XS mufflers
OLD:
1995 Dodge Stealth
Old 11-29-2008, 07:45 PM
BNaylor's Avatar
Good high end end scan tools can cost $5K or more. One of the replies was referring to the GM Tech 2 scan tool which costs that much. Of all the scan tools hard to beat it for what it does but for most us it is wishful thinking owning one. Different story if you are a professional auto tech with your own business servicing GM cars.
Timeslip 08/12/06
