Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-25-2008, 11:26 AM
kodriscoll kodriscoll is offline
New A.I.R. pump doesn't solve P0410 code issue
I have a 2000 Buick Century Custom, 3.1L, automatic. It is failing emmisions testing here in Utah, with the P0410 code. In searching the forums, I have learned that changing the secondary air injection system pump (i.e. AIR pump/smog pump) almost always fixes the problem. Unfortunately it didn't for me.
Are there any other causes of which anyone knows for this code?
Thanks!
Kent.
Old 12-02-2008, 02:49 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: New A.I.R. pump doesn't solve P0410 code issue
Welcome to AF
There are basically 4 components to the A.I.R. system that are controlled via the PCM:
1. the A.I.R. pump itself
2. the A.I.R pump relay
3. A.I.R. pump bypass solenoid
4. A.I.R. check valve (to keep exhaust gas from backing up into the pump when it's not commanded on by the PCM)
Any one of these item's malfunction could trip the P0410 code.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
