93 not starting in park
ok so its only happened once and has been fine since yesterday but if it doesnt start in park but starts in neutral whats the problem?? just in case this happens again
Re: 93 not starting in park
try this if it starts in neutral then put in park a push up on shifter to make sure its all the way in park then try starting it. you may have some ajustmants to do. and it may be your neutral safty switch that is if it don't the way i told you to. good luck..
Also, check the computers codes. A faulty neutral safety switch should set a code. At least it did with my '94!
2000 Cadillac STS 2005 Cadillac Escalade 2008 Triumph Sprint ST 1050 ABS |
