Old 11-24-2008, 05:17 PM
Mklangelo Mklangelo is offline
Unhappy Help with 92 LeSabre
I'm replacing the Front Hub/Wheel Bearing Assembly. What tool will I need to remove the three bolts holding the assembly? It looks like a Torx, but a T-50 is way too small and a T-55 too large. An 8mm hex is too small and a 9mm to large.
I tried a standard hex. 3/8 too small. 5/16 too large?
I'm stuck here. Is it a special tool?
Any help would be greatly appreciated. Thanks in advance.
Old 11-24-2008, 06:24 PM
Toymakerz Toymakerz is offline
Re: Help with 92 LeSabre
Get something small and pointed. Clean out the hole and try your t55 again I'm pretty sure that's the right size.
Old 11-24-2008, 06:34 PM
maxwedge maxwedge is offline
A990 racer
It is.
Old 11-24-2008, 08:25 PM
OK..I'm going to take another stab at it Wednesday night. I'll post.
Thanks!
Old 11-25-2008, 05:37 AM
Originally Posted by maxwedge
It is.
I do appreciate the help here guys, and perhaps I'm going crazy but I really don't think it's a T-55. I've had metric and Standard hexes in that hole so I know it's clean. I've had the T-50 and 55 as well, the 55 is just way too big.
Old 11-25-2008, 05:06 PM
Rasp Rasp is offline
The insides of the torx bolts get jammed with dirt and grit. It may seem like the bit won't fit but what is really happening is the hardened dirt is not allowing the bit to fit into the bolt correctly.
I had the exact same problem you had and I thought I was going nuts. I then started to clean out the head of the torx bolt and eventually stuff started to flake out. I then put the bit in and it worked.
