Old 03-19-2003, 10:22 AM
97cavi 97cavi is offline
Send a message via AIM to 97cavi
steering wheel
i wanted to get a new steering wheel for my cavi...but since there is a airbag in it some one said i cudn't...i dont think thas true is it? if not how can i? jes take the airbag out?
Old 03-24-2003, 07:56 AM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
you cant take it out, its agaisnt the law buddy.
PeacE
Old 03-24-2003, 08:07 PM
darn law:aug2:
Old 03-25-2003, 06:59 AM
Stali08's Avatar
ha ha the only reason I could take mine out is becuase my honda didnt have an air bag, but yea its definetly agaisnt the law, and i dont think u could take it out without it going off..i dont know.
PeacE
Old 03-25-2003, 08:41 AM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
I don't know.
This site says it's legal, and gives instructions on how to do so.
http://neptune.spacebears.com/cars/stories/airbag.html
Something from Momo:
http://www.sgmotorsports.com/mz3/momo.htm
And here's a quote from somewhere else.
"Yes, removing the stock steering wheel with air bag and replacing it with an
aftermarket steering wheel will work. Just remember to use your seat belts!
Remember without an airbag, you have 1 less safety measure. In most areas,
removing an air bag steering wheel (permanently) is illegal for the dealer or
mechanics but is legal for the owner to remove the device. In some other
areas, it is completely illegal to mess with the air bag. Please check with
local regulations first! After removing the air bag, the air bag light WILL
come on, unless you get an air bag boss. The device will fool the computer
into thinking the air bag system is working. Mazdaspeed has one such device
and I believe Momo also."
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 03-25-2003, 12:57 PM
sounds kinda dangerous...i hope tha air bag doesn't come out while i'm taking screws out...i think i will find out more about this...so why is it illegal for someone else to do it...if i give them permission? that seems pretty dumb...maybe for possible injuries i guess?
Old 03-26-2003, 04:12 AM
Pikachoo's Avatar
Sounds like as long as you disconnect the battery and wait 30 minutes then you won't have a problem with that.
Old 03-26-2003, 07:08 AM
Stali08's Avatar
okay well I guess you can, but still why would you wanna take a steering wheel out that has an airbag in, just to sacrafice a look? To me life would be more important, but thats just my 2cents. Good luck
PeacE
Old 03-26-2003, 01:01 PM
yea u gotta point...but i wear my seatbelt all the time!! lol and yea i am planning on disconnecting the battery and waiting more then 30 minutes...just incase!
Old 03-26-2003, 03:19 PM
Stali08's Avatar
yea thats cool i guess im just like this becuase im a voulenteer fire fighter, and i've seen some wicked crashes with cars and no air bags. But hey go with it, and when you get the steering wheel, just send me a pm so i can see it..mine of course is my avatar pic. Grant GT Evo, very nice wheel. easy too
PeacE
Old 03-27-2003, 04:08 PM
yeah i understand where your comming from...thanks for the advice tho!! but do you really think that without the airbag if i have my seatbelt on it will affect me a lot if i do get in a nasty wreck...i'll be profilein anyway!! lol so my head wont be hittin tha windsheild! but yeah i'll probly have it on in like a month...i gotta take care of some priorities first...but i'll send you a finished product pic when i'm done
Old 03-27-2003, 05:34 PM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
In case you need it...
Disabling the SIR System
Turn the steering wheel so that the vehicle's wheels are pointing straight ahead.
Turn the ignition switch to the OFF position.
Remove the key from the ignition switch.
Remove the left IP end cap. Refer to Instrument Panel (I/P) Outer Trim Cover Replacement in Instrument Panel, Gauges and Console.
Important
With the AIR BAG Fuse removed and the ignition switch in the RUN position, The AIR BAG warning lamp illuminates. This is normal operation, and does not indicate an SIR system malfunction.
Remove the AIR BAG Fuse from the fuse block. Refer to Fuse Block Replacement in Instrument Panel, Gauges and Console.
Remove the left sound insulator. Refer to Insulator Replacement - Instrument Panel (I/P) in Instrument Panel, Gauges and Console.
Remove the Connector Position Assurance (CPA) from the driver yellow 2-way connector located near the base of the steering column.
Disconnect the driver yellow 2-way connector located near the base of the steering column.
Remove the Connector Position Assurance (CPA) from the passenger yellow 2-way connector located near the base of the steering column.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 03-27-2003, 05:36 PM
SIR Service Precautions
Caution
When you are performing service on or near the SIR components or the SIR wiring, you must disable the SIR system. Refer to Disabling the SIR System. Failure to follow the correct procedure could cause air bag deployment, personal injury, or unnecessary SIR system repairs.
The inflatable restraint sensing and diagnostic module (SDM) maintains a reserve energy supply. The reserve energy supply provides deployment power for the air bags. Deployment power is available for as much as 10 minutes after disconnecting the vehicle power by any of the following methods:
Remove the fuse that provides power to the SDM.
Disconnect the vehicle battery from the vehicle electrical system.
Disabling the SIR system prevents deploying of the air bags from the reserve energy supply power.
Shop Foreman
Corvette Specialist
L1 Certified
Old 03-28-2003, 04:03 PM
thanks that helps alot! also the steering wheel i wanted to buy said "not airbag compatible" ... since i took mine out will it still fit? just making sure so i dont buy a steering wheel and have to put it on my wall or soemthing
