Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-24-2008, 12:29 PM
midnight_accord midnight_accord is offline
Exclamation P0135 Heater Circuit Help! PLEASE!
allright listen. i know a good amount about my accord. i have a 1999 honda accord lx. im on my 2nd motor which is the ulev motor and 3rd tranny which i recently just conversted from A/T to M/T. ok. now. i have one lkast code left onmy car everything else is good.
its p0135 primary 02 sensor heater circuit malfunction.
-i replaced the sensors with honda denso parts from dealer. made for my ulev motor.
-i checked the fuse and relay which both are good.
-i checked continuity under the hood to pin 4 which is the white wire under the hood.
i cant figure it out any help at all would be great thanks
Old 11-25-2008, 11:42 AM
somick's Avatar
somick somick is offline
Re: P0135 Heater Circuit Help! PLEASE!
In my codes library it just says an O2 sensor. Is there any reason you decided that this was a primary?
I would probe the secondary (after catalytic converter) one. If it proves to be good I guess you need to check the ECU pin outs, according to the electrical diagram, which I unfortunately do not have.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
