Old 11-24-2008, 11:24 AM
HondaCivic1995Sohc HondaCivic1995Sohc is offline
88-91 D15
Can anyone tell me the Tourqe specs for the bottom end for my 88-91 d15
Old 11-24-2008, 01:31 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: 88-91 D15
ound in:
* 1988-1991 Honda Civic GL/DX/LX
* 1988-1991 Honda CRX DX
* 1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
* 1990-1995 Honda Concerto (European Market)
o Displacement : 1,493 cc (91.1 cu in)
o Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
o Rod Length : 134 mm
o Compression : 9.2:1
o Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
o Valvetrain : SOHC (4 valves per cylinder)
o Cam Gear : 38 tooth
o Piston Code : PM3
o Fuel Control : PGM-FI Dual Point (OBD0)
o Redline : 6500 rpm (6000 rpm honda concerto) 7200 rpm rev limiter
Old 11-24-2008, 01:54 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
Re: 88-91 D15
pretty sure he ment tourque specs for assembling his motor. i would suggest you go and buy a shop manual, or go to the library, all the librays around here have all data so you can go print off what you need. or you can go to autozone.com and go to repair guides, they are the same as alldata as autozone owns alldata but its hit or miss weather you find what your looking for on there
Current cars
1990 honda civic dx High Comp mini me
1986 HONDA CRX SI
Need a winter mobile....
Old 11-24-2008, 05:02 PM
kris's Avatar
Re: 88-91 D15
ha, yeah, I guess so.
Then in that case, just start tightening things. When it starts to get loose, you know you have gone to far.
Old 11-24-2008, 10:35 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: 88-91 D15
I'd be mean here and describe torque-angle... but it would take too long.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 11-25-2008, 01:35 PM
Re: 88-91 D15
okay..... ive never done anything on a honda where you need a tourqe angle meter so yeah. seems like you post just to post these days man. give the keyboard a rest hahahaha..... no offense of course.
Current cars
1986 HONDA CRX SI
Old 11-25-2008, 10:49 PM
Re: 88-91 D15
Nothing actually requires torque-angle, it's just a better way to do it in some cases.
You're right though, I really need to get away from computers for awhile... it just sucks that I don't have work right now, so I'm sitting around my house alot.
OP, get a damn service manual.. it's $20, and it'll save you the days of waiting for someone to take pity on you and answer your question.
