Old 11-24-2008, 08:17 AM
jamesmetairie jamesmetairie is offline
car went clunk,clunk,clunk.
99 lx with about 128k. recently had wheels rotated . now i notice when driving about 40mph on a straight road and car moves to the left a little, as i give it a little right steering wheel to compensate i hear clunk and feel clunking in the steering wheel about 2 per second. also on interstate going about 65mph and to a curve to the right i have the same clunking. c/v boots ain,t busted. any idea,s will be appreciated. Jim.
Old 11-24-2008, 10:01 AM
rhandwor rhandwor is offline
Re: car went clunk,clunk,clunk.
If it started immediately after rotating the wheels I would put them back before you spend money looking. I had a new set put on a car and one tire was bad which caused pulling. Look for a bolt in the tire they cause clunking.
Old 11-24-2008, 12:39 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
See if lug nuts are tight.
Nevada Tumbleweed
Old 11-24-2008, 04:33 PM
zzyzzx2 zzyzzx2 is offline
Loose lug nuts.
If it still have the original outer tie rod ends, then they are way overdue.
Old 11-29-2008, 05:03 PM
clunking much worse.update= went back to sam,s club today for a redue. tech said he didn,t see anything really out of spec. but today the problem is much worse. shaking all the time at 50mph+. it seems to minimize as i accelerate. the plan is to take it to an old time suspension shop that does large trucks and buses,etc. will keep you guys posted.
Old 11-30-2008, 12:41 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Check the sterring rack and make sure it is securely mounted. I have found this to be an issue with a few Escorts... they like to work themselves loose over time.
Old 12-01-2008, 04:02 AM
clunk = bad tie-rod end. gave up and went to sears sunday afternoon. bad tie-rod end. i was so relieved i agreed to the alignment even though the car always drove straight as an arrow. total = $192. someday soon ill get the $25. tie-rod end at az for the other side and have my shady tree guy install it.
thanks for all you guys advice. i figured it was gonna be a lug nut.
