Old 11-24-2008, 12:17 AM
Ron21 Ron21 is offline
Question 2003 Grand Am hard to start when cold
My 2003 Grand Am is hard to start when cold. It doesn't seem to matter if it sits for 5 hrs or 20 hrs, it takes a few tries before it will start. The fuel pump was changed about a month ago. When the car is warm, there are no issues with starting and the car runs great weather hot or cold. It has about 110,000 km on it and has just start this problem
Any ideas what may be causing this?
Old 11-24-2008, 10:24 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 2003 Grand Am hard to start when cold
What engine does you 03 have ??
I would check for the usual, vacuum leaks, clogged/dirty injectors, clogged fuel filter, bad plugs and or wires.
1999 Grand Am SS 3.4 OHV
Old 11-25-2008, 06:28 PM
It has the 2.2L engine
Old 12-02-2008, 12:58 PM
3100 3100 is offline
Banned
I see you have mentioned Km I assume you live in Canada or somewhere where it is very cold, your car is 2003 and now is 2008, batteries usually last up to 5 years after that it is just a metter of time when you are going to stay somewhere on the parking lot unable to start. So if your battery is original replace it with new one and ask form more CCAs if you live in cold place. Also use 5w30 oil for better starts. Don't forget to check what Xero said also.....good luck
Old 12-10-2008, 01:28 AM
The car has a battery in it that is about a month old and has 5w30 oil in it. So far I have changed the plugs, Ignition Control Module. Check the injectors and fuel pump pressure but the problem still continues
Old 12-10-2008, 08:44 AM
Banned
how is your temperature gauge working?
Old 12-10-2008, 11:28 AM
seems to be working fine
Old 12-10-2008, 02:26 PM
Banned
Then your ECT sensor is ok, but if you want you can test it, you can find table with temp and resistances just Google it. But before that make sure all your battery cables are tight, engine ground good, starter terminals and cables clean and tight.
Old 12-10-2008, 07:20 PM
It could also be the IAC not functioning right due to a clogged passage in the TB. Might check that out too.
The temp sensor diagram 3100 mentioned is listed in the Tips and Maintenance sub forum.
Here's that
http://www.automotiveforums.com/vbul...lay.php?f=2148
And here is the IAC prcedure.
http://www.automotiveforums.com/vbul...d.php?t=663849
Old 12-20-2008, 06:38 PM
Finally got fed up and took the car to the garage. Turned out to be the spark control module. It has been running fine since that was changed
thanks for the help
Old 12-21-2008, 09:17 AM
That's great Ron!
But didnt you say in post #5 you replaced the ICM?!
Old 12-21-2008, 09:33 AM
Banned
good catch xi, plus the symptoms that he described do not indicate problems with icm, usually icm's could give you problems if they get too hot, not cold.
Old 12-26-2008, 11:41 AM
I have to agree with you guys
Well the problem has come back. I don't know what is doing it now and am lost. So far we have changed the
1. computer spark control module
2. coil pack
3. spark plugs
4. took IAC out and cleaned. Some carbon build up observered, haven"t replaced part though
5. battery was replaced in November
6. fuel pump was replaced in october
Should I replace the IAC. I am now completely lost and it is ovious to me the garage I took it to was lost also.
Old 12-26-2008, 12:10 PM
Hi Ron.
I would test the IAC before replacing it, they are not cheap around $65. Make sure the tip to base mounting flange is 1 1/8" too.
Here is a link that has the test procedure.
Also double check the vacuum line that behind the ICM/soil packs. Some times it gets loose or pops off and can suck air in causing these problems.
Wouldnt hurt to throw some injection clean in your gas tank, dirty(or icey from moisture) injectors can cause this too when its cold outside.
Old 12-28-2008, 10:57 AM
Banned
I knew that you will be back here soon, because something did not click right with your repair history, anyway the easiest way to see how your IAC works is just remowe IAC and whille it is connected tell somebody to turn inginion on and off you shoud see smooth movement in and out. Did you ever test you ECT sensor and compared it to the table of temp vs resistance. If ECT is telling your PCM wrong info about the engine temp lets say it tells pcm that engine is warmer than it is then pcm will not comand injectors to open long enough to alow more fuel for cold engine start.
