Old 11-23-2008, 09:15 PM
dmcogar dmcogar is offline
2000 taurus
Stalls at most every stop and won't stay running without foot on gas pedal. Replaced fuel filter already. Any ideas???? I'm a single mom and this is my daughters car. I hate to take it in without some idea of what might be wrong.
Old 11-23-2008, 09:27 PM
Scrapper Scrapper is offline
AF Premium User
Re: 2000 taurus
have you had fuel pump tested? if so it could be the tps snsor-throttle body sensor or maf sensor-mass-air-flow-sensor. is your check engine light on?
Old 11-23-2008, 11:47 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 taurus
Does it run roughly or is it pretty smooth? You could have a vacuum leak, misfire on one or more cylinders, or an EGR valve that is not closing fully if the car runs roughly at low engine speed.
If the engine is still pretty smooth until you let all the way off the throttle, I'd suspect a bad Idle Air Control (IAC), aka Idle Speed Control, servo or a badly carboned up throttle body.
-Rod
Old 11-25-2008, 01:58 PM
mattcruea mattcruea is offline
Re: 2000 taurus
This exact same problem happened to me a week or so ago on my 2000 Taurus Wagon. I guarantee you have a vacuum leak.
Old 11-25-2008, 06:47 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2000 taurus
I agree with Rod on the IAC. Try tapping on it with a screwdriver handle to see if it helps. A generic picture is below.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
